Power (Up/Down)grade going from TDs to cutout?
Old 06-10-2010, 05:54 PM
Gaunt's Avatar
Default Power (Up/Down)grade going from TDs to cutout?
Alright fellas, ripping the exhaust out of my car for clearance reasons primarily, and room to grow reasons secondarily.
Currently has a fantastic set of LPP 1 3/4inch stainless headers on it. goes into a 3inch TSP true dual system that dumps at the axle.
Switching to a TSP 1 7/8 inch header running to a 3inch electric cutout and a magnaflow catback.
Am I going to be losing power, gaining power, or staying the same (on this stock cubed 6 liter).
Car made 398 rwhp, 395 rwtq in its current form. In the end, it's probably only going to be a marginal +/- difference in horsepower, but I'm curious as I will be riding around on this setup for a year or so until the build comes together.
Old 06-11-2010, 12:52 AM
Gaunt's Avatar
Alrighty, here is the setup I have ordered.
TSP 1 7/8 coated headers
TSP ORY
DMH 3" electric cutout with QTP cutout
3" Magnaflow catback
Old 06-11-2010, 02:00 AM
King Nothing's Avatar
cuts outs closed i'll guess you'll lose but once you open you'll gain
Old 06-11-2010, 12:00 PM
Gaunt's Avatar
Cool thanks
I figured as much with the cutout closed, it was with the cutout open that I'm most curious about.
Old 06-11-2010, 01:56 PM
sscamaroburn02's Avatar
I'd like to see a dyno to see the gains/losses if any. I know TD"s flow pretty well but the cutout might yield a slight gain.
keep us posted when your new setup is on
Old 06-11-2010, 02:23 PM
CamaroZstyle28's Avatar
maybe a little power difference on the dyno but nothing that is noticeable when u punch it
Old 06-11-2010, 02:25 PM
jts98z28's Avatar
post up the dyno sheet if you get it dynoed im thinking about doing something very similar
Old 06-11-2010, 03:43 PM
Midnight02's Avatar
Shouldn't be a noticeable difference either way. In theory, larger primaries and the cutout should yield a little more power up top than the true dual setup.
Old 06-11-2010, 05:37 PM
Gaunt's Avatar
I don't really plan on dynoing the car. Probably a waste of money at that point. It's tuned as it is now, and it probably doesn't need a re-tune, and that would be the only time I would put it on the dyno. Just knowing that in theory, I should be making a few more ponies is good enough for me.
Old 06-11-2010, 06:16 PM
bww3588's Avatar
your going from TD's to a y and catback and how is this room to grow? TD's are the most efficient exhaust you can put on these cars.
Old 06-12-2010, 03:29 PM
Gaunt's Avatar
No... I'm going from 1 3/4 inch primaries and true duals to a 1 7/8 header and a 3 inch electric cutout.
The catback is not the point of this, I'm running a cutout.
And in my first post, I said ground clearance was the largest issue.
Old 06-12-2010, 05:52 PM
jerflash's Avatar
your going from 3" duals with bullets to a 3" y pipe to ONE 3" cut out. the 3" bullets dont hold back anything. i understand the 1 7/8 headers give you room to grow but the y pipe is going to hold you back anything over 500hp even with the cutout open. At your current power level the 1 7/8 headers, y pipe, cutout i think you will lose a little hp.
what you need to do is a setup like mine. it costs but worth it. I have american racing 1 7/8 headers and there 3" y pipe that goes to a magnaflow catback with an extra mufler in the i-pipe to control sound when crusin. But what i did was put 2 low profile oval cutouts from DHM in my y-pipe right after the first bends. IMO this is the best street/strip setup.
Old 06-12-2010, 08:57 PM
pharmd's Avatar
^I'm with jerflash...essentially he's running open headers with extensions when the cutouts are open, then a (hopefully) drone free catback when they are closed.
Old 06-13-2010, 02:50 PM
Gaunt's Avatar
Interesting.... I need to look into that.
Old 06-13-2010, 02:59 PM
jerflash's Avatar
my exhaust was pretty much drone free with the bullet in the i-pipe even with that crappy hooker y-pipe merge. now with this beautiful ARH y-pipe should sound sweet
Old 06-13-2010, 03:42 PM
Gaunt's Avatar
Thanks for the heads up, rarely do people offer solutions with objecting to an idea.
Old 06-14-2010, 09:44 PM
Gaunt's Avatar
Well, for what it's worth, I'm doing dual DMH electric cutouts, probably going to hack up the ORY a bit and put them just before the bend into the merge.
Thanks for letting me know guys.
Old 06-14-2010, 09:59 PM
jerflash's Avatar
thats pretty much what i did. depending on where you choose to put them and your y-pipe you should have tons of room
should be awesome
