Mustang K Members: AJE vs the rest
Old 06-10-2010, 08:24 PM
White40thGT's Avatar
Default Mustang K Members: AJE vs the rest
LS3 into an 03 Cobra, what are the pros and cons of the AJE swap K member vs other tubular K members and using the 4.6 mounts?
Someone told me I cant remove the trans in the car unless I have the AJE K Member because the AJE moves the entire assembly forward, not sure that I will need to but in the event something fails I'm not looking forward to an engine/trans pull.
Old 06-10-2010, 08:33 PM
Hugger67RSSS's Avatar
I live about 15 min. from AJE and have a good friend that has been there a long time. They are from my experience by far the best choice for your swap. You are correct about it moving the engine forward. I can ask him any questions you would need to know!
Old 06-10-2010, 08:39 PM
How far forward does it move the engine?
How much space is between the engine/firewall and engine/fans with the AJE K Member?
I need to make sure I have room to route the turbo piping.
Old 06-10-2010, 09:57 PM
Gray86hatch's Avatar
It moves the engine back about 3/4" from where a 302 would be with a Aje
Tim
Old 06-11-2010, 08:14 AM
feldz82's Avatar
I went with a qa1 4.6 k. $180 w/control arms off ebay.
Old 06-11-2010, 01:38 PM
Anyone have any measurements or information that actually applies?
Old 06-12-2010, 07:25 PM
themachasy's Avatar
Is it aluminum or iron block? The extra motor mount holes on the alu motor will make a difference. If you don't want to cut, weld, and modify, just get the aje setup.
If you're local to Miami I can bring the mockup motor out =)
Old 06-12-2010, 10:26 PM
I will give him a call tom. and see what all the specs are on the setup. I need to talk with him anyway...
Old 06-14-2010, 07:17 PM
I talked with him tonight. He said the bellhousing will be in the same spot as the factory tranny and will be able to remove it without problems. He has a scratched display model he would sell really cheap. PM me if you want his number
Quick Reply: Mustang K Members: AJE vs the rest
