Is this the driveshaft, does this look normal? idk...
Old 06-12-2010, 05:13 PM
PwrHngryLT1's Avatar
Default Is this the driveshaft, does this look normal? idk...
Hello, well I recently purchased my first ls1. Its a 99 ss 6 speed. Today i pulled out the middle console to install my new mgw shifter along with a new rubber boot and shift ****. While in the open I noticed something that seems strange to me between the shifter assembly and the opening leading to the ground. It just looks awkward to me. First of all is this the driveshaft im looking at? seems to show signs of turning for a good 1"-2" in length? Like if it were moving forward and back? Normal? Any input would greatly be appreciated. Thanks! still in the process of learning...
Attached Thumbnails Is this the driveshaft, does this look normal? idk...-sdc12803.jpg   Is this the driveshaft, does this look normal? idk...-sdc12802.jpg   Is this the driveshaft, does this look normal? idk...-sdc12811.jpg
Old 06-14-2010, 10:48 AM
z28evans's Avatar
That is your driveshaft, and things look normal
Old 06-14-2010, 11:23 PM
th3unwant3d1's Avatar
looks fine
Old 06-15-2010, 12:26 PM
96lt1m6's Avatar
That wear pattern is from suspension travel and normal use...
Old 06-15-2010, 12:53 PM
kool, great to know all is good, thanks guys!
