Dynamometer Results & Comparisons - Dyno results ls1 gto FAST 102/102
HellaciousA
06-12-2010, 08:30 PM
Much thanks to Charlie @ RPM Motors for spending so much time dialing in the tune. Car was tuned in SD, the MAF is there to help make passing smog a bit easier (will enable MAF for smog test and adjust tune at that time). LS6 injectors that were flow tested/cleaned/blueprinted--think they are around 30s at 87% duty cycle.
Car put down 460/423, up 23hp/25tq from the old numbers (437/398). Dynomite Dyno as well. I've only driven it briefly, but pulls a lot harder and is noticeably louder. The gas pedal is hard to push, don't know if it's just stiff being the throttle body is new or that is normal, but slow speeds have had some bucking just because Im not used to it. Finally done with the power mods, onto getting it to hook/handle/brake better.
http://www.indi-x.com/gallery2/d/8352-1/dyno33.jpg
http://www.indi-x.com/gallery2/d/8350-1/engine2.jpg
http://www.indi-x.com/gallery2/d/8348-1/engine1.jpg
madmike9396
06-12-2010, 08:35 PM
what is all ur mods that is some pretty good numbers
pharmd
06-12-2010, 09:54 PM
is the FAST ported or stock?
HellaciousA
06-12-2010, 10:27 PM
FAST manifold was smoothed and ported
243 cnc'd heads by rpm motors, larger valves, upgraded valvesprings
224/228 114+2
kooks 1 3/4" LTs
SLP UDP
SS OTR CAI
Spintech catback
RPS twin disc clutch w/ built t56
Johnnystock
06-12-2010, 10:47 PM
Sounds like very healthy numbers to me, congrats OP. 102mm FAST is badass
98z8uup
06-13-2010, 03:05 AM
Sounds like good strong car.
allngn_c5
06-13-2010, 07:10 AM
Quite impressive gains.
pharmd
06-13-2010, 07:27 AM
224/228 114+2
kooks 1 3/4" LTs
SLP UDP
SS OTR CAI
Spintech catback
Time to update your Sig #'s!!!
MYSTIC-1SC
06-13-2010, 12:03 PM
very nice improvement.
ramairws6
06-13-2010, 12:31 PM
Very nice gain! Especially with that baby cam. Take that bad boy to the track and lets see what she's got! :D
427LS7HCI
06-14-2010, 09:17 AM
Very nice cold air inake setup!
Gregory
06-14-2010, 11:35 AM
Very respectable, and the engine bay looks super clean!
Jim'sZ28
06-14-2010, 11:58 AM
sorry if I missed it,was this an LS6 intake prior?
HellaciousA
06-14-2010, 08:20 PM
Yes it was, w/ a stock 78mm tb and stock MAF
