2nd Gen Camaro guys, need some input on a Track only 6.0L stuff
I am getting my stuff together to build a Track only 1970 drag car using a carbed 6.0L for the engine.
I am wondering if the truck oil pan is going to hang too far below the crossmember. Years ago we used to run deep sump Moroso oil pans at the track, since they were track only we never had much troubles with a pan that hung pretty low.
I think it would work but I would like to hear others thoughts on it.
it will hang low. A F-body pan will fit alot better. I got my Fcar pan kit from www.partstaxi.com They were the cheapest when I was checking for the best deal at the time. (something like $280.)
I have a F-body pan I can use.
Did you replace the truck oil pump with a F-body oil pump??
When I bought my f-body pan it came with the windage tray, pan, and pickup tube, what else would I need to do the swap??
