New Dyno Tune But .....
Installed LE1 heads and cam 226x230-111 but I ran 12.9s with stock heads and cc 305 and now best 12.80 @ 106.9 W/1.80 60ft . DA was bad,3100 but still think times should be better..can find nothing wrong.
I don't have the papers from the tune, tuner was not there when I picked it up. I just talked to him,he wants to look at in again this week.Top end is all comp cams 1.6rr.push rods,lifters,retainers,locks ect.& LE's springs w.heads. I'm goinng back to track today for points racing.
Check this out to see what a closer time would have been for that day. I know its not completely accurate, but it will give you an idea of howit would run in better weather.
http://www.dragtimes.com/da-density-...calculator.php
Having good valvetrain components is one thing, and setting it up properly is a whole nother thing.
Could be some of your issue, or not. Wondering what the tune looks like
I'de get it on a dynojet if you want accurate #'s. If you are truly making 395rwhp in an unlock auto you would be trapping near 120. I trapped 111 with 322rwhp when I was an auto just for reference. As far as the track times they seem on par with similar setups in that d/a.
I have the same cam with le2 heads. Your peak hp#'s arent too far off, but your torque curve looks terrible. mine looks like the sideview of a kitchen table. I made 405/392 through an m-6 with stock gears. Ran out of fuel pump around 6300.
I'm still on stock injectors & stock TB..we were thinking about them..The tuner I deal with has the superFlow dyno and he's local, I'm going to meet with him tues.and look at the tune first..
Any idea what would cause torque curve to be like that ?
