Single Digit Club - 9.98 146mph
View Full Version : 9.98 146mph
HAHASSRAG
06-14-2010, 09:56 PM
Wow first time out ran above expectations.Peddled it to 9.98 @ 146 mph.2002 Trans Am vert ,427 twin turbo, 4l80,3:54 S60 ,4200lbs plus my 215lbs, 315 17 inch drag radials, straight pump gas, no meth..................thank Campbell Auto:D
http://img256.imageshack.us/img256/1613/phpuwxtzopm.jpg (http://img256.imageshack.us/i/phpuwxtzopm.jpg/)
2001WS6Vert
06-17-2010, 07:28 PM
And I thought I was heavy. Good to see another fast vert. I wish I had a 9 sec. slip:(:(:(. How did you get those tires to hook? What was your 60' and 1/8th?
MY99TAWS6
06-18-2010, 10:54 PM
Hear about your car on our local board. Sounds nuts. We have same rear end and same gears. How is yours for noise.I have some decel whine but otherwise good.
What stall? How do you get that thing to hook up. Are you using two step?
Great times. That is pretty much my exact same goal..run a 9.99 or better. Don't you have to go to overdrive for that mph with those gears. ?
I would think my car is going to come in at 4000. Haven't weighed it yet. Hope to track and dyno sometime this year. Still debating if should put in rollbar so can at least practice a bit otherwise can only run at outlaw tracks.
Also you are running those new high impedence super pricey injectors.? How are they working out for you. Do they idle nice ,any surging at idle or off.
Congrats on the 9s.Sure has lots more in it.
SlickVert
06-19-2010, 07:47 PM
Congrats!
That's flying, let's see some pictures of your car and video of the run.
Bob
C Murda
06-20-2010, 09:10 AM
9s with a 1.6 60'!!!! not so much in the hook as it is PULLING LIKE A MOFO!!!! vids please if you got any!! im doing the same build but with a 6 speed and 800 less pounds
HAHASSRAG
06-20-2010, 12:31 PM
To see engine dyno and Quarter mile run vids go to forced induction section and look for 427 twin turbo dyno vids:drive:
MY99TAWS6
06-20-2010, 12:57 PM
Wondering about a few mods.
So you were running et drag radial or et street radial?
What stall in the car?
So are you spool or locker or just posi like mine? I was wondering how the posi will stand up at big power. Was thinking to go wavetrac when they come out with it later this year or early next according to wavetrac.
Are you ramping your boost by gear,rpm,time??
What is your full suspension list..shocks, springs, torque arm,etc.
Do you run a tunnel mount torque arm or relocated to crossmember one.
You were running alc injection on pump? 50%50 or 100% meth?
HAHASSRAG
06-20-2010, 04:46 PM
315 17 et streets, boost by gear,usual rear suspension withcrossmember mount torque arm. No acc or meth,100% Husky premium:drive:
MY99TAWS6
06-20-2010, 05:10 PM
What make torque arm? I am hitting that damn tunnel with my bmr and same rear end. Have moved it over with panhard, hammered on tunnel,Also my torque arm seems to also make knock noise when braking. Might want to switch it out for another type if is quieter and has more tunnel clearance.
What shocks and springs?
HAHASSRAG
06-20-2010, 06:32 PM
Not sure what type of torque arm, on car when I got it,QA1 up front stock springs and shocks out back. I have QA1 s for the rear that will be installed soon. Car will be on display at the Rocky Mtn Nationals in Edmonton this comming weekend................
obZidian
06-22-2010, 10:46 AM
Great mph with that weight. Dumb question, what are you using to get boost per gear with the auto?
HAHASSRAG
08-09-2010, 09:37 PM
9.711 145.81 in crappy air,thanks Campbell:eek2:
Frozen WS6
08-09-2010, 10:09 PM
That's flying. 145mph.
black98ws6ta
09-06-2010, 09:14 PM
Congrats on the times!
I built a "box" to drive my eboost 2 with the 4l60/4l80e. Not sure how he done it.
HAHASSRAG
10-26-2010, 10:28 PM
Snow has come and car is now stuck in my garage.Had it out to track 3 times with a 9.7 145 best at 15 psi. Tons left in the car just need to fine tune the suspension. Drove her on the street over 1000 miles [1600 km] and the car has run flawless.Car has far surpassed what I was looking for..............thanks to all the gang at Cambell Auto:chug:
HAHASSRAG
12-06-2010, 06:38 PM
Cant wait for spring:sack:
tomz28
12-24-2010, 04:06 PM
how much boost? dose it say 15psi on the slip
