06 gto fuel injectors?
i am trying to figure out what fuel inectors come stock in the 06 gto . i have looked and i just cant find anything. if you can please explain how much power the stock injectors can hold as well, thank you.
Stock injectors are good till a bit under 500(ish)rwhp when boosted or a bit over 530rwhp when all motor. And thats all i know about them for now.
They also do fine with a 150 shot.
The LS2 uses 32# injectors. Once you go above 450 rwhp, I would have your tuner carefully check injector duty cycles. Upgrade the injectors if you go above about 80% at WOT.
