installing new moser axle in 00 camaro
Old 06-15-2010, 05:44 PM
gokussx4's Avatar
Default installing new moser axle in 00 camaro
How do you get the wheel speed sensor gear off the old axle to put on the new one? Techniques used would be great! or do I have to get new?
Old 06-15-2010, 06:07 PM
gokussx4's Avatar
Looks like the appropriate name is abs sensor ring. Thoughts?
Old 06-15-2010, 06:33 PM
69TA's Avatar
you can either do it with a press
or rig up a jig with some pieces of wood
supporting around the ring and then tap it out
Old 06-15-2010, 07:09 PM
gokussx4's Avatar
Thanks for the advice, I was hoping that I wouldn't have to buy a new pair.
Old 06-15-2010, 08:06 PM
Justins00ss's Avatar
yeah usually you can even heat them a little and then press them off.
Old 06-15-2010, 08:59 PM
SS SLP2's Avatar
use two small pry bars or two large screw drivers and blocks of wood , they are not tight, have changed several this way to reinstall I put the axles in the freezer for a few howers and the rings in hot water and they will slip on with no problems,,
PS side note:
look close or mark the up side as they need to go back on the same side up
Johnny
Old 06-16-2010, 01:42 PM
gokussx4's Avatar
Thanks Johnny! Thats a great idea
