Ignition issue on turbo ls6
Old 06-16-2010, 07:02 AM
V8RX7FTW's Avatar
Default Ignition issue on turbo ls6
Basically I will give a run down of a random issue I've been having. Basically car will idle and run strong. Then sound will change and a whole bank of coils will just quit working. Sometimes it will come back and cut out. Sometimes it runs fine. Very random. As far as things I've checked and looked at. Coil packs are relocated and all seem to work. 12 volts is supplyed via the pink wire even when a side drops out. grounds on head are attached via one bolt. " I was told that they need to be seperated on two bolts?" Have yet to try that. Plugs are tr6's with new wires and all protected from heat. Engine has two heavy grounds. I visually check the spark at each coil and when its running good a nice purple spark is there. When a side drops nothing. Even more bizzare is if I pull a wire off the coil it will bring the side back almost like there is a interfence in signal or something. Hope thats enough detail but feel free to ask if I missed something.
Old 06-16-2010, 07:20 AM
Old Geezer's Avatar
Stock harness that's modified, or a custom made?
Fuses?
Old 06-16-2010, 07:22 AM
V8RX7FTW's Avatar
stock harness powered by a painless 7 fuse box setup. Fuses are all good
Old 06-16-2010, 12:54 PM
juicedgta's Avatar
yea ***** weird for sure......it would run perfect and then started it up later and there it is again
Old 06-16-2010, 04:30 PM
juicedgta's Avatar
problem fixed....wire came loose and was arcing
