New LS1 Owners - Newbie Tech - head and cam on 98 trans am
bornoel
06-16-2010, 08:11 AM
I have a 98 trans am with slp loudmouth1, bassani y pipe, bbk shorties, bbk 85mm TB, SLP Lid and mass air flow sensor, ls6 intake manifold, and 3.73's. Im looking for a good head and cam package that is good on the street. Im looking at getting ls6 2.5 heads from tsp and the torquer v3 cam. Along with that ill be getting a ls6 ported oil pump a ls2 timing chain, and a 3300 stall. Is this a good setup for my trans am? Im open to any sugestions. Thanks!!!
MonmouthCtyLS7
06-16-2010, 09:24 AM
You'll be choking that heads/cam setup through those shorties, Id concentrate on getting some LT's first. Good choice though on the heads/cam . I was looking at those heads w/ a 224 cam.
Jon@Texas-Speed
06-16-2010, 09:27 AM
I think it's a good combo as well but the BBK headers will be fairly restrictive on that aggressive of a combo. We would probably do a little smaller custom grind if you are looking to keep them or if you want to go to a LT header pretty quick you can get by with this combo until you get them. You just won't see the full potential of what this heads/cam combo will produce.
Jon
bornoel
06-16-2010, 09:53 AM
Jon
Jon,
I talked to just a couple of days ago. I called you from afghanastan. I will be talking to you in person before to long. I leave this country in a few days and should be in amarillo in a month or so. I really want this set up. So ill probably have you throw on a set of longtubes when i get the rest of this stuff on. Thanks for the advice.....If you can think of anything else I would appriciate it. Thanks!!!!! Noel
bornoel
06-16-2010, 09:55 AM
Thanks for the advice. I bought those shorties before I even thought about doing head and cam package. Im going to get some longtubes at the time of the install. What kind of rear wheel hp do you think i would be looking at? Thanks!!
cowboysfan
06-16-2010, 07:24 PM
380 to 400 rwhp with mentioned setup.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
