Drag Racing Tech
2 step settings
Old 01-15-2004, 12:45 PM
algws6's Avatar
Default 2 step settings
what should i start my 2 step at? its a heads & cam car with 4:30s and tires will be 27x11.5 QTPs (street shootout) @ around 11.5 psi. track prep should be pretty good. thanks.
Old 01-15-2004, 01:00 PM
FEAR THE LS1's Avatar
You got an auto or a manual?
If you have an auto whats your converter stall to?
Seeing you have 4.30's and 27" I would guess you have a manual, if so with QTP's try a 3500 stutter launch and go up in 500 rpm increments. Compare your 60' times on each pass. You'll find the sweet spot to set the 2 step to.
Lee
Old 01-15-2004, 01:20 PM
The Juggernaut's Avatar
I have the same combo.(even down to the PSI)
It launches the best @ 6400-6500.But people tell me I am crazy.
Mid to low 1.5x's all day long
Old 01-15-2004, 01:25 PM
Fireball's Avatar
I set mine to 6400 rpm. best 60' to date = 1.473
Old 01-15-2004, 02:32 PM
algws6's Avatar
i guess ill start at 6k. i cann't wait to launch off the bottle (on 28 et drags of course)when i get my fuel noid back.
