'95 4L60E Valve body in '94?
Old 06-16-2010, 05:29 PM
Boman6760's Avatar
Default '95 4L60E Valve body in '94?
Ok so my bellhousing split on my '95. I now have a '94 4L60E that I am swapping over the 3-2 seloniod and the pwm + harness(thanks again performabuilt for this info). Since my '95 had been rebuilt once before I bought the car I decided to look around inside it. And I found it has a transgo seporator plate #46-95 in it. On research this is '95's only and then '93-'94 has there own and so on. I called transgo and they said to just swap the entire valve body('95 valve body into '94trans) with 3-2 and pwm and harness and it is good to go with the '95 seporator plate. I just wanted to see if anyone thought otherwise or this sounds right on. Just dont need to buy another trans anytime soon.
Old 06-17-2010, 11:09 AM
Boman6760's Avatar
Anyone before I try it?
Quick Reply: '95 4L60E Valve body in '94?
