Noise coming from rear area
Old 06-16-2010, 08:35 PM
JerseyLS1TA's Avatar
Default Noise coming from rear area
There is a noise, not a squeak but more of a woomp woomp woomp sound, don't know how else to explain it lol, coming from the rear of the car. It's there all the time and is noticeably loud when driving slow but you can still here it over the exhaust when cruising. Is it just normal noise these cars make as they get older or is it some other problem like wheel bearings, rear, etc etc?
Old 06-16-2010, 10:11 PM
Adam2001WS6's Avatar
Video/sound clip?
Old 06-17-2010, 01:24 AM
sjsingle1's Avatar
rear end? suspension?
Old 06-17-2010, 01:01 PM
ArkBird96's Avatar
If you are stock, it's your rear. Mine did that and most of the bearings were gone. It sounds like your rear axle is on borrowed time and will probably need a rebuild soon.
Old 06-22-2010, 06:13 PM
Yeah its stock, seems to have gotten worse after multiple runs down the drag strip. It's only got 80,000 miles also. Anything I can do to prolong it, rear diff fluid change etc??
Old 06-22-2010, 09:24 PM
Only a matter of time no matter what you do if you are taking it to the drag strip... sorry my friend, but I'd start saving up for a beefier rearend.
Old 06-23-2010, 12:44 AM
nimrod.sixty9's Avatar
I would have to say bearings... If thats the case, axles too.
Stay far away from Timken or any sort of repair kits...
Ill see if I can find my old threads and you can see if it sounds like your current situation.
Old 06-23-2010, 01:43 AM
http://www.fullthrottlev6.com/forums...ad.php?t=55729
http://www.fullthrottlev6.com/forums...ad.php?t=57912
http://forum.camarov6.com/showthread.php?t=98484
Some posts say their symptoms and a whole lotta Timken fail
Old 06-23-2010, 04:13 PM
well im def done at the strip for a while. Guess I need to find a good mechanic who knows a lot about rears and go from there, don't really want to take it to a GM dealership
Old 06-23-2010, 04:33 PM
Its worth checking it out yourself. Youll save a lot of money if its just axles/bearings.
Its much easier than it sounds/looks
Old 06-25-2010, 04:51 PM
Yeah luckily my buddies step father owns a shop one town over and said he would do it for me, might as well upgrade these 2.73's while he's doing it
