Nitrous Oxide - Backfires after spraying?
01SOMZ28
06-17-2010, 07:47 AM
Is it normal to get a lot of backfiring after a nitrous run?
Nitro Dave's Nitrous Outlet
06-17-2010, 01:40 PM
Can you be more specific... You should not have backfires...
What does your set up consist of and is it back firing through the intake or exhaust.
Dave
01SOMZ28
06-17-2010, 01:43 PM
It backfires through the exhaust 75% of the time after making a run on the spray and some are pretty good POPS!
06-17-2010, 01:56 PM
Is it a directport?
01SOMZ28
06-17-2010, 02:10 PM
No, i have your plate.
TA1364
06-17-2010, 02:23 PM
Mine does the samething
Sounds like unburned fuel lighting off in the headers.
06-17-2010, 06:49 PM
The poping through the exhaust is normally unburned fuel. What is your airfuel ratio on the bottle?
Dave
01SOMZ28
06-17-2010, 10:33 PM
Dave
I thought it was probably unburned fuel as well. Not sure what the afr's are on the bottle, its been a while since i was on the dyno. I'd have to find my last dyno sheet and look. I haven't changed anything since then.
XtremeDime
06-17-2010, 10:38 PM
You dont have a wideband or a means to log anything?
01SOMZ28
06-17-2010, 10:51 PM
...no....:emb: I live life on the edge. I haven't had a wideband or anything to long the last 2 1/2 years i've had the nitrous on the car. Although i have been looking into getting a wideband here recently...
6point7s14
06-18-2010, 07:31 AM
Pulled your plugs to look?
Chris@NitroDaves
06-18-2010, 01:55 PM
I'd make a pull and then kill the car and pull some plugs to see where your at on fueling. The plugs are going to be the best way to find out without a wideband cause the plugs are the all tell.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
