how does this cam look for a carb aplication?
I contacted comp cams and this is what they recommended i have custom ground for a carburated LQ9 in a 3,000 lb daily driven car.
Part #: 54-000-11
Grind #: 3753/3735HR110+4
Duration @ .050": 224/230
Lift w/ 1.7 Ratio: .534/.539
LSA: 110
Advance in cam: +4
I dont know much about cams so am looking to see what you all think.
Part #: 54-000-11
LSA: 110
Advance in cam: +4
By looking at the specs could you tell me what the engine would run like with just the cam and the performer manifold with a carb and MSD box. the rest of the engine would be stock
clearance should be ok, but I would double check piston to valve clearance anyways to make sure. And you WILL need springs with that cam. Stock springs arent good for much. Eric L
