Cadillac CTS-V - 2007 TBSS Throttle Body on V?
View Full Version : 2007 TBSS Throttle Body on V?
itsslow98
06-18-2010, 12:21 AM
Ive heard this will work but wanna see if anyone has done it. I know its a 4 bolt which is why i want it so i can put a FAST on my car. I just want to make sure it will still connect to the harness without modification.
greddy91
06-18-2010, 12:40 AM
Is it not just a standard LS2 TB?
itsslow98
06-18-2010, 12:53 AM
http://media.photobucket.com/image/ls2%20throttle%20body/shotababy14/newcar003.jpg
http://www.eadperformance.com/1003/ls2intake3.jpg
greddy91
06-18-2010, 01:31 AM
Daaaayyyyuuuummmm that thing is ugly.
ColeGraham
06-18-2010, 05:42 AM
who cars what the engine looks like...the hood is down most of the time...as long as you can add to numbers to RWHP, its all good in my book.
itsslow98
06-18-2010, 03:07 PM
couldnt agree more, the FAST intake and nitrous solenoids will make up for it.
cts-vls6
06-18-2010, 04:38 PM
its will not work on ur car u need a ls2 tb the wire and connector is diff. on a tbss
CTSV_510
06-18-2010, 06:47 PM
The LS2 tb connector is different too...you need a ls2 to ls6 connector harness to make it work.
itsslow98
06-18-2010, 07:41 PM
i can get it for 60 shipped, where can i get the connectors? ls2 TB off GTos are going for 300 bucks.
i see katech sells one for 50 bucks anyone else?
AWDTBSS
06-18-2010, 08:48 PM
isnt the tbss tb smaller than ur ls6 tb? tbss is iirc 87mm and the v is 90mm.
but if u get it port it made a huge difference on my car
itsslow98
06-18-2010, 10:15 PM
The V has an LS6 TB which is 78MM just like the intake manifold. So porting a TBSS TB will still put it around 90mm and will allow me to bolt up at a FAST which is the main reason for buying it.
AWDTBSS
06-19-2010, 01:03 AM
Ya prolly, I don't have that bottom lip on my tb
JonCR96Z
06-20-2010, 01:27 AM
I think the blade itself is where the size comes from.
Anyway, the harness that you're looking for probably doesn't exist. However this is a common (well maybe not common) swap for trucks that have the older 78mm TB/intake. The harness that they require costs $200 bucks because it actually has to convert the signal to make it run this style of TB. So yours would probably be similar.
You can get LS2 TBs for $200. Just have to look for them.
Gus_Mahn
06-20-2010, 08:05 AM
Where can i get the connectors?
i see katech sells one for 50 bucks anyone else?Caspers Electronics
(http://www.casperselectronics.com/store2/product_info.php?cPath=54&products_id=1489) sells lots of harness parts and plugs maybe they have an adapter harness.
