Would these rims fit?
The numbers look fine but just checking before I order them. I have Zero Drop rear springs and have my fenders cut. And will get drag bags if needed. And what's the BS for skinnies that I would need with minimal grinding ?
Can be found on summit. I'd post the direct link but I don't know how the mods are with non sponsor links.
Weld Racing 71MB-510B75A
Wheel, RTS, Aluminum, Polished/Black, 15 in. x 10.275 in., 5 x 4.75 in. Bolt Circle, 7.50 in. Backspace, Each
"fit" is a relative term as to me it means the wheels can go the full travel of the suspension without rubbing and also not look like a 4x4. Also the build variability of these cars means that a close fit on one car won't work on another as the side-to-side spacing of the rear cradle seems to be different on every car. I would think that with that wheel width there may be issues with the inner fender and shock contact without modification.
