Old 05-20-2016, 10:02 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Chevrolet Camaro or Pontiac Firebird Engine Guides
Print Wikipost
Installing mechanical oil psi gauge
Old 06-19-2010, 01:48 AM
SS4Luck's Avatar
Default Installing mechanical oil psi gauge
I got tired of my stock guage pissing me off and acting up on me and ordered a mechanical autometer gauge just so that i know 100% for sure whats going in my motor. The only problem is i dont know where to put the sending in to the motor to get a reading. I know that i need an oil galley plug, but i have no idea where they are, and how to get the plug out/sending unit in.
I also got an electronic fuel psi, but ive put those in before off the end of the rail, so im not too worried about that one.
Pictures, details, anything would be of help
Old 06-19-2010, 07:19 AM
Jim_PA's Avatar
I used this, and re-drilled and tapped for NPT: 12551587
This gasket: 12553210 (gasket)
And these bolts: 11588714
See here: http://www.ls2.com/forums/showthread.php?t=654515
Old 06-19-2010, 06:52 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
Pull the stock oil pressure sending unit out and get Autometer part # 2268. Once you got it just install the oil pressure gauge like normal
I've got mine like this and haven't had any issues
Old 06-19-2010, 07:24 PM
Jontall's Avatar
Many people use this also:
Old 06-20-2010, 01:41 AM
Maroslut2001's Avatar
I use the glow shift thing the only thing i dont like about is it lowers your filter a little ways... I also suggest you swap the plastic line that came with your guage out for a copper one, the plastic line kinks easy and i had one burst on a jeep i use to own so from now on i make it a point to use the copper lines instead lol
Old 06-22-2010, 10:10 PM
SS4Luck's Avatar
Is there not a place i can just drill and tap? im not interested in lifting the manifold to install the adapter if there is a place i can just tap. If i have to i will, but god i really really dont want to lol
Old 06-23-2010, 12:22 AM
Sounds like the glowshift adapter would be good for you, it fits in between your oil filter and block it will lower your oil filter about 3/4- 1" but the only time i have had problems is when i had to drive my camaro in the snow, the harder deeper snow dented the filter a little bit.
Old 06-24-2010, 07:21 AM
SS4Luck's Avatar
any idea on waht to search to find info on something like that?
also what size is needed?
Old 06-24-2010, 12:23 PM
Trunion King
bene's Avatar
junkman2008 did a DIY thread awhile ago here...
https://ls1tech.com/forums/generatio...n-dummies.html
Old 06-24-2010, 09:26 PM
SS4Luck's Avatar
i just had my motor apart and am not in the mood to pull the intake and everything off again
Old 06-27-2010, 09:17 PM
SS4Luck's Avatar
Ttt...
Old 06-27-2010, 09:35 PM
http://www.glowshiftdirect.com/Oil-F...-Adapters.aspx
Thats the link to there site with the adapters... they have a number on the page you can call and ask what size you need, sorry for the late reply and sorry i cant remeber what size i got.
Old 06-28-2010, 06:05 PM
SS4Luck's Avatar
no worries, i just didnt know if thats where you had got yours from or what. Thanks for the help man
Old 06-29-2010, 08:43 PM
No worries man... I got mine off of ebay a couple of years ago thats why i dont know the size, i searched around on there for them but i couldnt come up with anything.
Old 06-29-2010, 09:44 PM
BigRich954RR's Avatar
Anyone know what size glow shift would be need for a 06 GTO ?
Old 06-29-2010, 09:49 PM
This looks like a great way to read psi and have a take off for a turbo oil line This take the psi reading before the filter right ?
Old 06-29-2010, 09:50 PM
If you follow the link i posted there is a little ad in the middle of the page with a number you can call to find out what size you need.
Old 06-29-2010, 09:59 PM
Yea i saw that add but i wanted to order it now so i could be at my housde by friday
Quick Reply: Installing mechanical oil psi gauge
