LT1 to LS1?
Old 06-20-2010, 09:32 AM
Boo"SS"t's Avatar
Default LT1 to LS1?
What else do I have to change in order to convert a t56 out of an lt1 f-body to my '01 ls1 f-body, I know that the input shaft, front plate and bellhousing are different, are there anything else that I'm missing? and are any differences in the gear ratios? -thx!
Old 06-20-2010, 09:13 PM
Turnin20s's Avatar
I'm interested to know this as well. I'm planning an LS swap and would like to know if I can use my T56 rather than buy another stock one and take a risk if its good or not.
I have heard input, bellhousing, and front plate as well but nothing for certain
Old 06-20-2010, 11:18 PM
haighter's Avatar
There are a few differences in the lt1 trans'. The older ones have different gear ratios so you won't be able to get the correct imput shaft to fit a ls1 set up unless it's custom.
Old 06-21-2010, 10:00 AM
Boo"SS"t's Avatar
Any experts out there willing to shed the light on this???
Old 06-25-2010, 09:05 PM
LS123's Avatar
93 LT1 T56 has different ratios and is the "bastard" year. 94 and up T56 are the same as LS1 T56's with 2.66 first gear. If you want to change the LT1 T56 to LS1 T56 specs, you need to change the following:
Midplate (also known as the front cover)
Input shaft (also known as 4th gear)
Bellhousing
People have replace just the input shaft and the midplate but not recommended. I would disassemble the entire trans and set the shims correctly.
Old 06-27-2010, 01:14 PM
ratrod1988's Avatar
Hey, I have 1968 camaro with a ls1. I have a lt1 t56 with the flywheel,pressure plate, clucth and all. what would i have to change to put the t56 behind my ls1. Is the clucth the only thing different?
Old 06-27-2010, 04:20 PM
Turnin20s's Avatar
Why don't you read the above posts, that will answer your question
Old 06-27-2010, 04:23 PM
Turnin20s's Avatar
Bellhousing
Nice, thanks for the input, I also plan on changing my 2nd gear, new syncros, and a steel 3-4 fork and I probably forgot some stuff but you get my point
Thanks again
Old 06-28-2010, 12:32 PM
iansane's Avatar
What? Maybe the '93 only trans but the rest are fine. I swapped from LT1 style clutch/input/frontplate when I get rid of the SBC and went with an LSx in my bird.
Quick Reply: LT1 to LS1?
