Swap chevelle, new tune new times
Old 06-21-2010, 09:26 AM
thunderstruck507's Avatar
Default Swap chevelle, new tune new times
Went to try the new tune and 25% ud pulley out
DA was 2930 at the last time listed on dragtimes.com but humidity went from 50% to 68% by 11pm according to the weather updates on my girlfriend's phone,
Ended up making it to finals for a 2nd place win. Lost because I broke out, but I was happy because it was a new best even though I lifted
60ft 1.791 (spinning noticeably)
330 5.068
1/8th 7.857
mph 84.66 (car was trapping high 88.x mph when I wasn't lifting)
Car weighs ~3700lbs+ and was running on 275/50/15 Nitto 555r with 22psi
Previous best was 7.902@ 87.8 mph in 2600DA with the same 60ft, not lifting any
Old 06-21-2010, 01:59 PM
Does this seem about where I should be for my mods?
Cam peaks at 6000, I'm shifting at 6300 so the FAST might not be helping a ton more than a ls6 intake would but I got it cheap.
Old 06-22-2010, 05:57 PM
blk/slvr02ss's Avatar
I would say u had to much air in your tires.I have the same tire and run 18psi and same converter and got a 1.63 60ft w/ a 7.53@90mph.
Old 06-22-2010, 06:25 PM
"The Drag Racing Director"
Coach 02 A3 Z/28's Avatar
330 5.068
1/8th 7.857
Sweet car. Congrats on the runner up finish. I agree on tire psi being to high.
Coach
Old 06-23-2010, 08:49 AM
I've tried running them at 18psi before and pulled the same 60ft with them still rolling over several times.
Old 07-13-2010, 09:56 AM
EZZZE's Avatar
17-18 psi cold
Old 07-13-2010, 05:50 PM
Ph.D. in HUBRIS
custm2500's Avatar
Drop down to 14-16 if you still spin at 18 psi.
