Advanced Engineering Tech - lost compression!!!!!!!!!!!!!!!!!!!!!!
victor111262
06-21-2010, 05:24 PM
Need help lost compression and the car dosent turn on.
well i was driving and the car just turn off after one day of the swap, it showed a code crank sensor but the sensor looks good could that be it.
RTRx7
06-21-2010, 06:12 PM
The car won't run without compression.
Do a compression test to see which cylinders are gone.
victor111262
06-21-2010, 06:14 PM
none of them are good and i cant believe it mest them up driving 30 miles per hour and then just cut off i think is the valves cos i was running it just open stock exhaust manifold
RTRx7
06-21-2010, 08:02 PM
Wow.
Head gasket?
Sharpe
06-22-2010, 02:13 PM
http://www.ls1tech.com/forums/advanced-engineering-tech/1274283-notice-forum-theoretical-discussion-repair-threads-use-other-forum.html
...and...
http://www.ls1tech.com/forums/advanced-engineering-tech/396223-what-forum-please-read-before-posting.html
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
