Flywheel question..
Old 06-21-2010, 09:45 PM
98z-28redcamaro's Avatar
Default Flywheel question..
i have a zoom clutch.... Hp series..... i have the zoom flywheel that came with the kit.... my question is will the zoom flywheel work with other clutches such as centerforce, ram, mcleod,ect......
Old 06-24-2010, 11:25 AM
Old 06-24-2010, 03:03 PM
All-In's Avatar
Location: Just because the voices aren't real, doesn't mean they're not right!
Unless it has some unusual characteristic, such a recessed friction surface or something, or if it's aluminum and the steel friction surface does not match the new clutch's disk size, etc, then I see no reason it why it wouldn't work. If you do use it, I would recommend resurfacing and then getting it, and the new clutch of choice, balanced AS A COMPLETE ASSEMBLY.
HTH
