Convertible Vehicles - Needing to buy!!!
cecrowder
06-22-2010, 04:19 PM
I am needing to buy the following part #10286318 - Quarter Window folding top filler (93-02 convertible) RH.
This is the triangular piece that is attached to the rotating arm right behind the door windows.
I would like to buy a used one if possible. Can somebody suggest where I might obtain one. I have tried the local salvage yards but all they have are hard tops and t-tops.
Sunset01TA
06-22-2010, 08:09 PM
try the dealer
cecrowder
06-22-2010, 10:19 PM
Thank you for the reply.
I have checked with the dealer. At $140 for this piece I was hoping to find one cheaper.
cecrowder
06-23-2010, 01:00 AM
Using the search term "trans am sail", I was able to locate an aftermarket replacement. It is made of Carbon Fiber and is available for both the coupe and convertible.
For those who might also need this item, the link is:http://cgi.ebay.com/ebaymotors/93-02-FIREBIRD-TRANS-AM-CAMARO-CARBON-FIBER-SAIL-PANEL-/290443628252?cmd=ViewItem&pt=Motors_Car_Truck_Parts_Accessories&hash=item439fca0edc
Sunset01TA
06-23-2010, 07:53 AM
the part you listed is for a cover "Sticker" that goes on top of the actual piece.
If you are missing the Triangle you'll have nothing to put the decal on.
http://www.gmpartsgiant.com/parts/gm-filler-10286318.html
munecorey
06-23-2010, 05:01 PM
Buy it at gmpartsdirect.com they cost around 85 dollars shipped!
cecrowder
06-27-2010, 01:49 PM
You are correct that this a sticker. It is not the "perfect" replacement, but it will cover the triangular space until I can purchase a replacement part. It does however attach to the rotating arm just fine as there is plenty "structure" there that the actual filler attaches to.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
