4l60e problems and ???????s please help
Old 06-22-2010, 08:50 PM
superstu23's Avatar
Default 4l60e problems and ???????s please help
ok i had my transmission rebuilt at 80k i now have 100k on the car and the dam planaterry bearing in the trans has broken again if i have it fixed will it happen again >?is there a stronger bearing assmbly to put in there or should i buy another trans from monster transmission or somewhere like that ?please help thanx
Old 06-23-2010, 07:21 AM
72blownvert's Avatar
The bearing does fail quite often just get a rebuilt planetary assembly with a new bearing installed.If you have a lube problem then the planet and sungear and ringear will be black and smell burnt.Depending on what year your trans is the hole in the output shaft could be a problem with exsessive end play which is usually in early units unless someone put an early shaft in a late unit. If those parts are not black in color then the bearing just failed.
