Quick !AIR Question
Old 06-23-2010, 02:23 AM
xKellyxVeitx's Avatar
Default Quick !AIR Question
What can I use to plug the holes in the stock exhaust manifolds?
Old 06-23-2010, 06:24 AM
SSweet97's Avatar
Do a search on "Block Off Plates". I'm quite sure you will find an answer. Also, post your question on Camaro Z28.com if you don't find out on this forum, but I'm sure you will find your answer in this forum.
Old 06-23-2010, 09:18 AM
defaultexistence's Avatar
Kelly ,find some threaded pipe plugs from a hardware store ,usually have a square head on em' to be tightened with an adjustable wrench,Also ebay is your best source for so much as you begin your install/modding. look for egr block offs,pumps,...alll kinds of stuff there . ~Michael~
Old 06-23-2010, 09:20 AM
MasterTomos's Avatar
just did bolts in mine and had them welded
Old 06-23-2010, 11:16 AM
Low N Slow's Avatar
Try an M22 oil drain plug
Old 06-23-2010, 11:24 AM
RamAir95TA's Avatar
OBDI cars use an M22 plug, OBDII cars use an M18 plug.
Old 06-23-2010, 01:27 PM
Originally Posted by ramair95ta
obdi cars use an m22 plug, obdii cars use an m18 plug.
drain plugs ftw!! Dude!!!! Lol
Old 06-24-2010, 09:14 PM
Is this rule absolute? My motor was thought to be 1997, but the M18 was too tiny.
Old 06-24-2010, 09:43 PM
RamAir95TA's Avatar
Hopefully I don't have it backwards. Try the M22.
Old 06-24-2010, 09:44 PM
Oh my.
