Those with Hals, what are you setting the ride height to?
Old 01-16-2004, 02:24 PM
ThaBeaSSt's Avatar
Default Those with Hals, what are you setting the ride height to?
I was just curious as to what you all are putting them at? The car is set up for drag use and street use. I didnt know if you set them lower, higher, or at the same height as stock. I want to get the best performance at the track, so what am I going to set them at? Thanks a lot.
Old 01-16-2004, 02:55 PM
ThaBeaSSt's Avatar
Sorry for all the Hal questions, but if you turn the **** all the way to the left (counter clockwise) is that 0 or 1? Thanks
Old 01-16-2004, 03:03 PM
WicketMike's Avatar
ttt for ya, id like to know also
Old 01-16-2004, 07:40 PM
DrkPhx's Avatar
Turning counter clockwise is looser. Use the top center edge of the wheel well as a reference point to measure. Make sure to take before and after measurements with the car parked in the same spot.
With 18" C5's and 275/35/18 tires mine measured 28" at stock height, I dropped the front to 26.5" after to give it a slight rake.
Old 01-17-2004, 04:20 AM
jfm
jfm's Avatar
I would set it at least a half inch higher because it will lower itself over the next couple days.It is easier to lower the car than raise it with the wrench they supply.
I used a steel rod and a marker to make a story board for driver/passenger side height.
Old 11-05-2004, 02:00 PM
WicketMike's Avatar
do you just turn the **** to adjust it? or do you have to use the wrench they supply you with at the top and adjust that also?
thanks
Quick Reply: Those with Hals, what are you setting the ride height to?
