MAF P0171, P0174 issue
2002 pontiac firebird, replaced what I thought was a faulty MAF sensor about a year ago. Long story short, I replaced the stock unit with a SLP MAF, and the computer is throwing codes about being too lean on bank 1 and 2 (again).
I'm almost convinced that the SLP sensor is faulty. If I clean the MAF with MAF cleaner and clear the codes the computer in the vehicle is happy for a random amount of time (a day, a week). I have been unable to find any vaccum leaks, and I have not replaced the PCV valve.
Since I don't have the original MAF what would be a cost effective replacement (other than the stealership). I really don't want to throw a few hundred dollars at this, if the fix is simpler. So I'm asking what could I have missed? The vehicle engine is very near stock. Only a catch can, a new K&N filter, and MSD wires. The car runs absolutely fine otherwise.
Suggestions on what it might be or what would be the best replacement MAF other than the SLP version?
Thanks
-JB
Thanks
-JB
maf
hi, it seems like the after-market mafs make the car run lean. i had a Granatelli and it would cause my car to run lean. i had already sold my stock one so i just bought a good used one. you can find them for 40.00. mine has worked fine and i have not thrown any codes. put a stocker back in.
Matt, would that be behind the throttlebody I presume? Or am I way off the mark?
Cleared the code again to day (drove fine the whole day, until 1 minute from my house) and to my surprise it also threw a P0300 (random misfire). No blinking SES, no loss of drivability, idle etc. WTF.
Thanks everyone for all the suggestions. I appreciate the help. I'm definitely going to put the stock MAF back on. I'll have to wait until Sunday for a moment go leak hunting.
Last edited by Wisp; 06-26-2010 at 01:53 AM. Reason: spelling, additional details.
While following Matt's advice, I found a hairline crease on the return line to the throttle body. The line was slightly kinked in a way that (I assume) made the vaccum leak intermitant. Replaced the line, checked the others (and the plug wires for that P0300) and reassembled. Hopefully, this will fix it.
