19x10s wont fit...
19x10s wont fit...
i just tried installing my c6 wheels and the rears wont fit... even with a 1/2 inch spacer... i havent tried the passenger side yet. just the drivers side its hitting the bumpstop do i need an adjustable panhard?
You need a larger spacer. 1/2 inch is about 13mm. You need at least a 1.25 inch spacer to bring the offset low enough for them to fit. I just took off my c6 79mm wheels and used a 1.25" spacer with them.
I have two I can sell for $55 shipped btw, about 300 miles on them.
REAR Only
10.0" ... +38 to +54 mm .... 275, 285, 295
What is the offset on the wheels? They must not be corvette 79mm..because a 1/2 inch spacer would bring it down to 66mm, which is no where close to fitting.
they arent oem corvette wheels...
here is the thread i bought them from...
https://ls1tech.com/forums/parts-cla...hined-lip.html
I originally thought they were oem wheels. Aftermarket are a different story. You'll be fine with after you center the rear.
i have 315 toyo dr's that bulge a little bit on my c6 18x10.5's. i just beat the fenders in where they scrubbed and used the adjustment on my panhard rod. they're perfect now..no rubbing at all. and they look great!
