LS4 Performance - Torx Bolt on Rotors
06ImpalaSS
06-26-2010, 11:12 AM
Anyone know if the torx bolt that bolts the rotor on the hub is needed? Friend and I were changing the rear rotors and pads and the torx bolt's head completely stripped. I went to Napa and they said just said use a screw extractor to get it out, but they said I dont need to put one back in because its just used during assembly in the factory. Thoughts?
pro_performer
06-26-2010, 11:16 AM
I don't think they are....from what I understand, the torx bolts are used by dealerships to hold the rotor in place so the dealership can turn/resurface the rotors while they are on the car. when i replaced my rotors, i removed them as 1 had stripped and i had to use a drill to split the bolt to remove it.
2005gxp
06-26-2010, 11:20 AM
some rotors have them and when you get new ones they wont have the holes, they are not necessary to have.
06ImpalaSS
06-26-2010, 11:27 AM
Thanks for the quick responses.
pro_performer
06-26-2010, 11:28 AM
No problem! We're here to serve
EmersonHart13
06-28-2010, 04:42 PM
Not necessary and occasionally very annoying!!
CenTexSS
06-28-2010, 07:43 PM
I've kept mine in there, it made easier for when I put the caliper back on with the pads in it!
Panther427
06-29-2010, 03:30 AM
A dealer would just zip on a couple of your lug nuts back on to keep the rotors flush.
06ImpalaSS
06-29-2010, 09:44 AM
Yea we just had to drill out the bolt until the head snapped off. All is good now. What a pain in the ass though when you dont have an air wrench to loosen stuff.
BuffaloSS
06-29-2010, 12:57 PM
I broke two torx bits before I said fk it and drilled the head off. I left the nub there, though...mainly b/c I'm pretty lazy. ;)
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
