do i need a new timing cover?
Old 06-26-2010, 12:23 PM
Purple94Z28's Avatar
Default do i need a new timing cover?
i am in the process of putting a cam in my car and i realised my timing cover had a piece missing is this bad?
It may be hard to see but towards the left lip on the bottom that attaches to the oil pan it has a chipped off piece. Will that still seal or should i find a new one?
Old 06-26-2010, 12:30 PM
Badazz 97 TA's Avatar
I would just get a new/used one. I wouldn't chance it. Only because its a lot of work to get it off if it does happen to leak, ya know.
Old 06-26-2010, 12:34 PM
thats what i was thinking
Old 06-26-2010, 12:35 PM
BlackBird87's Avatar
does it look like a fresh break. Did it leak before the swap
Old 06-26-2010, 01:06 PM
my front main leaked bad and i think it happened after i took it off motor but there is no way of telling
Old 06-26-2010, 01:35 PM
1badzee's Avatar
It doesn't seem as if it would seal good. I would get a new one to play it safe.
Old 06-26-2010, 01:38 PM
Low N Slow's Avatar
I would be looking for the piece that broke off, it's probably in your oil pan.
Old 06-26-2010, 11:24 PM
letsrun97z's Avatar
I got one if you need pm me
Old 06-27-2010, 06:56 AM
Ironroad9c1's Avatar
Its fine
Old 06-27-2010, 07:29 AM
71ANTICARB's Avatar
I'd run it. There is a lot of pressure on the sealing surface being so close to the bolt. And when you compare it to the other side there is realy not that much missing.
Old 06-27-2010, 07:58 AM
71ANTICARB's Avatar
Old 06-27-2010, 12:53 PM
would a 95 cover fit a 94 motor?
Old 06-27-2010, 01:24 PM
airfix's Avatar
nope you'd need a 93-94 cover. But honeslty yours doesnt look that bad I'd run it and put a little extra rtv around it.
Quick Reply: do i need a new timing cover?
