Pulled axles, replaced studs, center block that holds axles wont fit!!!!:(
Old 06-26-2010, 01:01 PM
donnj's Avatar
Default Pulled axles, replaced studs, center block that holds axles wont fit!!!!:(
Like stated, pulled axles and replaced the studs, all good. Installed C clips and the paddle will not slide in like it came out. It misses by a tiny bit, any help before my cousin takes a BFH to it and it all goes south......
thanks in advance
don
Old 06-26-2010, 11:57 PM
Viper's Avatar
Dremel a little off, don't use the BFH.
Old 06-27-2010, 02:27 AM
roy
roy's Avatar
Put a slide hammer on the axle shaft and give a a couple good whacks , then do the other side. Ensure the calipers are not mounted prior to doing this.
