A/C diagram
A/C diagram
does anyone have a diagram of the 1998-2002 camaro or firebird a/c system, i need to know where the seals and o-rings go i am trying to reinstall a new a/c system on my 1998 transam, thanks guys i had no luck after 2 hours of searching.
In a nutshell, anywhere you have a mechanical joint you have an o-ring. That's the only kind of seals there are, except the mechanical seal on the compressor crankshaft which you can't see or change.
