LT1 WOT AFGS at high rpm
Old 06-27-2010, 11:26 AM
aboatguy's Avatar
Default LT1 WOT AFGS at high rpm
What numbers AFGS (airflow grams/second ) are you seeing on your datalogs at WOT.... and how much of a pressure drop are you seeing between baro and the map readings?
I've been searching for a little while what the normal pressure drop and MAF AFGS for modified LT1s are .... Please post your:
Engine size
RPM
AFGS
Baro
Map
Intake air temp
Or better yet post a datalog screen shot.....
At high rpm in decent air my 355 hits the 370s heres a 360 in great air...
Here's 371 in good air
MPH difference is change in tire/wheel size......
Thanks
Mike
Quick Reply: LT1 WOT AFGS at high rpm
