28 spline 8.8 swap
Old 06-27-2010, 05:45 PM
mtuggle86's Avatar
Default 28 spline 8.8 swap
Im planning to swap an 8.8 into my car soon im trying to do it as cheap as possible for this year and switching over to 31 spline axles and carrier next year.
My question is does anyone have any info on swapping a mustang 28 spline rear end into a camaro while using the stock 10 bolt 28 spine axles in the setup to save money?
Old 06-28-2010, 07:47 AM
Detroitmuscle's Avatar
what do you need to know? I'm doing the build right now and its not any different using 31 spline axels and a 31 spline carrier than it is using the stock 28 spline stuff.
Old 06-29-2010, 12:12 AM
mtuggle86's Avatar
Hey im on Mifbody too. I wondering about using the 28 spline ford 8.8 then just using my stock 10 bolt axles for a year or so until im ready to throw more money at it and upgrade to a 31 spline carrier and custom moser axle.
Im wondering how well it works using the stock axles and how much abuse can this setup take
Old 06-29-2010, 01:16 AM
1BAD01TA's Avatar
yes your stock 28 spline axles will work with the 28 spline ford posi, and for abuse I know a few mustang guys that have gone 10.0 on stock mustang axles but that is a lighter car.
Old 06-29-2010, 01:29 AM
93sspcoupe's Avatar
when u go t o 31 spline you can get a carrier out of a wrecked v8 explorer. they have 31 splines stock. but the stock 28spline ford axles will handle some abuse. i'm using ranger axles in mine and there still intact
Old 06-29-2010, 06:35 AM
I think you'll be fine especially with your goals (11s)
Old 06-29-2010, 07:11 AM
mtuggle86's Avatar
Ok i think Ill try this first how easy has your swap been detroit?
Btw off topic but does anyone know if a ls1 hooker y-pipe will fit a 3rd gen z-28 with headers?
Old 06-29-2010, 07:32 AM
well not much going on with the swap so far so yes its been really easy. We cut the axel tubes off the 8.8 and the 10 bolt. Then I bought some round stock and made a pair of sleeves for them and now I'm having a guy setup my new gears and then it'll come together for final welding. We also made a nice torque arm bracket that we can set with the rear up in the car and then final weld that on. I'm hoping to have it done and in the car before the fall.
Old 06-29-2010, 11:59 AM
Randy WS6's Avatar
The GM axles are not that strong, I broke both of mine at the track on Nitto's. When you deside to upgrade to a 31 spline carrier, I have 3 of them if you need one , I went to a mini spool, so i dont need them any more.
Old 06-29-2010, 12:05 PM
I've got 31 spline stuff, but thanks for the offer Randy
