where to get a cable from,,, aldl obd2
where is a good place to get a aldl cables to datalog... I'm trying to find a good cable that with hook up to a obd2 style plug and interface with a pc... I've seen some cheap ones on ebay for like 10 bucks but i'm kinda scared of them ...But i also don't want to spend like 100 bucks on one either if a cheaper one will work just as good
http://www.aldlcable.com/sc/details.asp?item=obd2usb
this is what i have and it works great! works with any OBDII system. i have checked lexus GM nissian and several others. i also bought the PCMSCAN data logger. the only thing i don't like about PCMSCAN is you cant see the IAC count and knock count!
hope this helps!
hope this helps!
i like the PCMSCAN other than the fact that i can't see the knock count and the IAC count. other than that it's great! i think i have $220.00 in the whole set up! if you are looking on the internet stay away from MYSCANTOOL...huge rip off!!!
