4l60e is not shifting out of 2 or 3 ?
You need to get codes and go from there.Theres alot of things that could put it in failsafe thats why you need to scan first.post code #s when you get them.
You are in limp mode. My guess is that you have an electrical issue. Does your speedo work? If not, there is part of your problem. Also, do you have a high-stall torque converter? If so, you need to tune out the test for the P0757 code in the PCM. Scan for codes and let us know what you find.
