4L60E Cooler Line keeps popping off
What is causing my cooler line to pop off? The e-clips and the plastic clip over it are both there but it keeps popping off. Pressure in drive is like 200-220psi. Any ideas?
I would double check to make sure your lines are not crack that pop on.
What I did with mine is put the clip on the line then take it up to the tranny and snap it on.I sometimes had to wiggle the sh*t out of it to make it snap on.
Did it for sure snap on?
