Injectors and a tune...need help
Ok well I had posted a while back that I took my car to the track and it ran 11s all motor however it was falling flat on its face at around ~5600.. well I was finally able to talk to the original owner of the car and found out its on stock injectors and a mail order tune??? He said the guy told him that stock injectors will handle 500hp and not to worry about it...the mods are as follows tell me what you guys think...
Setup
TEA CNCd heads 55cc chambers, 2.0 intake valves, 1.56 exhaust, dual springs, comp LT1 3315s/3316s cam (.544/.554 230/236 112LSA) 1.6 Rockers
Heads flow
.6000 229.1 263.5
355 bottom end (eagle crank, rods, Ross pistons)
11.1 compression
Ported intake
Holley 58mm Throttle body w/ K&N intake
Hooker LT to ORY through a Magnaflo bullet and dumps before the axle
Electric Water Pump
Th350 Tranny with 275 low gear
PTC 3600 converter
Full manual valve body (NO Trans Brake)
Moser 12 bolt 4.10 gears
Weld Prostars MT 28x10.s full slicks
Setup
Heads flow
.6000 229.1 263.5
11.1 compression
Ported intake
Electric Water Pump
PTC 3600 converter
