clearence with pushrod guideplates?
Okay so i just bought scorpion 1.6 rockers with a 3/8 stud and some trickflow guide plates i was curious do i need to have my heads milled down to accept the guide plates?
Thanks,
Nick
Thanks,
Nick
Village Troll
I was answering the part as to whether or not you'll need machining for guideplates. You will not. As far as pushrods go you should always check the length when changing out valvetrain components. You can easily do a valve sweep check. Do a search on checking valve sweep.
Village Troll
More than likely, yes. Another term that can easily be searched and found how to do. You can probably get info from shoebox's page:
www.shbox.com
www.shbox.com
