Drag Racing Tech
13's @ LACR Almost stock?? Elevation: 2700 FT
Old 01-17-2004, 01:54 PM
EvilSVT's Avatar
Default 13's @ LACR Almost stock?? Elevation: 2700 FT
I was wondering with my mods listed below if iam gonna hit 13's .. even if its a 13.99 i dont care as long as its 13's .... Iam pretty sure iam going to but elevation kills 2700 Feet!!!!! Thanks
Old 01-17-2004, 03:20 PM
gator's 99TA's Avatar
elevation is gonna hurt you but not that much. guys are running 13.9s in DA of +4000 feet
Old 01-17-2004, 03:25 PM
EvilSVT's Avatar
So pretty much It will run 13's most definately ??
Old 01-17-2004, 04:02 PM
Big Stick's Avatar
Man, you can hypothesize and benchrace all day long, but the only way to know is to actually run it!
Old 01-17-2004, 04:38 PM
Terry Burger's Avatar
My old 2001 ran a best of 14.1 up there stock, on drag radials. After a bunch of bolt on mods it ran 12.8 though.
Old 01-17-2004, 05:19 PM
Chris81's Avatar
It should run in the high 13's pretty easy.. my home track is 3000 ft with DA's usually above 4000 ft. (the DA in my sig was at the end of Nov.) I've run 13.40's in 4000+ DA's numerous times.
In the summer here in West Texas the DA's were nearing 6000 ft sometimes and I was running 13.80's with 2.2 60' before I changed the clutch and got DR's (prolly would have gone 13.5-6 in that horrible air with current mods).
Old 01-17-2004, 05:40 PM
EvilSVT's Avatar
all i know if it doesnt Beat my trucks 14.0 i hit there iam going to be very dissapointed!
Old 01-17-2004, 08:00 PM
Fred99LS1's Avatar
Before you get pissed, realize your in control of that M-6. That truck shifted for you. My first time at the track i went 13.31. The second time with some drag rad's and practice I went 12.82. Be advised the tach reads slow at wot. Be prepared to have to shift at 5500 indicated the first run to get a feel for it.
Good luck, Fred
Old 01-18-2004, 12:09 PM
EvilSVT's Avatar
i know ALOT depends on driver .. but iam a damn good driver ... not trying to brag but iam so ... iam pretty confident in doing it but just wanted to see what ya'll thought... later
Old 01-18-2004, 12:50 PM
Fred99LS1's Avatar
Personally, I don't think you will have a problem running a 13. Once you get back from the track post your time slip. I never raced at 3500-4000 feet myself. I would throw some drag radials on before I went to really see what the car has got. Good luck & let us know how you did, Fred
Old 01-18-2004, 12:56 PM
EvilSVT's Avatar
Thanks Fred..... I def will post!!!! And its not to bad ... 2700 feet.... so we'll see ... thanks again
Old 01-18-2004, 03:03 PM
bad2000ss's Avatar
The problem with LACR is of course the altitude. Not only is it 2700' physically, most nights you can get a DA of 4000'+. Then, compound that with some of the worst track prep i've seen. DO NOT pull out your air filter if you think you can pick up a little more power, its not worth the potential damage to your motor. Had to to clean a brand new K&N filter after a day of racing there, WAY too much dirt in the air. If you can't run a 13 or whatever your goal is, don't be dissapointed. Just an example, i ran a 2 tenths better 60' at irwindale than palmdale, and i ran 6 tenths better 1/8 mile at irwindale than palmdale.
Old 01-18-2004, 03:43 PM
EvilSVT's Avatar
Well if i went today which it is not open..... The DA as of right now is 2682 Feet ... which wouldnt be to bad .... but we'll see what its at Wednesday!! I have had ok luck with traction never thought it was TOO bad but it is bad ... i cut a 2.0 60' in my lightning on F1's (close to bald) So if i hit at least a 2.2 60' with the DA around 2700... i know i'll hit 13's
Old 01-18-2004, 07:48 PM
WicketMike's Avatar
should be able to, i ran 13.9 there bone stock in the white T/A
Old 01-21-2004, 04:11 PM
WS6dan's Avatar
Probably came in a little late but I ran 13.53 at 104.9 at LACR with only a TSP lid no other mods not even free ones. You should be able hit the same times as me. This was in my 02 t\a with 6500 miles.
Old 01-21-2004, 04:39 PM
EvilSVT's Avatar
Those are some pretty good times for that track... what was your 60' time???? iam gonna go tonight to check out my time
