LQ4 wire to cable conversion for throttle needed
Old 07-01-2010, 01:45 AM
22lambo's Avatar
Default LQ4 wire to cable conversion for throttle needed
I need to convert the wire to the throttle body to be a cable. Could I just put a ls1 throttle and have it work? I would like to know what is the way I can have a cable on the LQ4. Thanks.
Old 07-01-2010, 05:11 AM
poconojoe's Avatar
A lot would depend on the on the year, etc.
You need to switch the throttle body for a cable,
Add the IAC, and TPS wiring to the harness,
Have the PCM flashed with a DBC OS, not all DBW PCM's can be flashed to DBC, since they don't have IAC drivers in them
Old 07-01-2010, 08:56 AM
22lambo's Avatar
It's out of a 2006 Sierra. Could I use a LS1 PCM?
Old 07-01-2010, 05:57 PM
poconojoe's Avatar
What color is the crank sensor plug?
Old 07-05-2010, 01:54 AM
22lambo's Avatar
Where is it? I couldn't really find it in the time I had.
Old 07-05-2010, 05:19 AM
Pocket's Avatar
Behind the starter
Black = 24x
Gray = 58x
Old 07-05-2010, 08:47 AM
22lambo's Avatar
Originally Posted by Pocket
Behind the starter
Black = 24x
Gray = 58x
Thanks! So what's the deal with the colors then, if it's gray I can't use the LS1 PCM or something?
Old 07-06-2010, 04:16 PM
alitz's Avatar
Bump so will it work with a black plug???
Old 07-06-2010, 04:30 PM
LS1TECH Sponsor
Schwanke Engines's Avatar
You could send me your PCM and I will get you the right PCm for the job. If it is an LQ4, it is more than likely a 24x. If it is grey, you will not be able to run cable as there are no IAC motor drivers in any of the 58x controllers.
Old 07-06-2010, 04:34 PM
alitz's Avatar
How much and do you happen to have the cables??
Old 07-07-2010, 08:48 AM
LS1TECH Sponsor
If you are getting just a base cal, it will be $185.99. We have 36" Lokar LS1 cables for $55.
There are probably some other things that you need. Give me a call and I will get a complete list together.
Quick Reply: LQ4 wire to cable conversion for throttle needed
