Steel driveshaft vs. aluminum driveshaft?
Old 07-03-2010, 10:02 AM
Slash8915's Avatar
Default Steel driveshaft vs. aluminum driveshaft?
I'm about to have my car dynotuned, and I had a quick question... My car was in an accident a few years ago, and the guy that fixed it used stock parts off of a non-ws6 ta. I know he replaced the swaybars, and I think he MAY have replaced the driveshaft.
I was told that if I have a steel driveshaft, I can kiss my 400rwhp goal goodbye, and that I would need an aluminum driveshaft to do that. Is there any truth to this?
Old 07-03-2010, 08:12 PM
jerflash's Avatar
if it was a trans am then it was an aluminum shaft but why dont you just look under your car and make sure? if its aluminum it will look aluminum
Old 07-03-2010, 08:15 PM
jsteele90's Avatar
steel shaft is stronger. just keep it on there if it is
Old 07-12-2010, 01:12 PM
98RedRocket's Avatar
the steel ones can vibrate at high rpms and can cause cracking.
Old 07-12-2010, 01:59 PM
Moderator
jimmyblue's Avatar
Yeah, every report of cracked tailhousing I have seen,
was on a steel driveshaft and a gear swap. Stock piece
seems to whip when overspun.
Aftermarket steel ones are a different story. But flogging
the bargain basement one is looking for luck you may not
have.
Old 07-13-2010, 10:03 AM
Slash8915's Avatar
Well, turns out I have an aluminum one, so I should be good. Lol.
Quick Reply: Steel driveshaft vs. aluminum driveshaft?
