HELP! Dynatech headers burning plug wire
Old 07-03-2010, 10:56 PM
myz06's Avatar
Default HELP! Dynatech headers burning plug wire
On the #5 cylinder, if you know Dynatech's, the header tube runs parallel and not down. I have to move my coil pack way down to even hook up my truck wires (have 6.0 in 69 Camaro). Is there anything else longer or to do besides relocating the coils? The dang boot on the plug is so long and practically touches the inside tube. I've even put on heat socks, shields, and still burn them up. It's been like 4 now. I would like to put the coil pack back up with the others but can't. It's even tight running behind. Ideas or pics? Thanks. Yes, tried an 8.1l wire as it's a tad longer but the boot off the plug was huge and laying all over the tube. Maybe a 90 on the plug would help to go in between???
Old 07-04-2010, 12:25 AM
350SS's Avatar
dang, that sucks...I've been wondering about the fitment of the dynatechs for my Nova...
The truck wires are going to be the longest I think. Do you have any pics? That might make it easier to come up with a solution if we can see the problem...
A couple of things to consider, aftermarket wires like msd or taylor will probably have a smaller boot, but I don't know if that will solve the problem.
Another option would be modding some LT1 or 96-98 vortec truck wires which use the same spark plug and coil ends.
Old 07-04-2010, 12:45 AM
myz06's Avatar
The headers are great because of the ample clearance of the power steering pump but do suck for burning up the wires. A guy suggested some NGK 120 degree boot ends that worked for him so might try that. Thanks.
Old 07-04-2010, 01:59 AM
350SS's Avatar
I've never heard anyone trying these but google wrenchrat sparkarm. I'm curious to hear if they work... they'll probably look stupid though, unfortunately.
Old 07-04-2010, 02:13 AM
myz06's Avatar
Never seen those. Different. Like you said, probably won't look right, but might work like a charm.
Old 07-04-2010, 09:23 AM
Pop N Wood's Avatar
Get the MSD wires with the multi angle boots. They are a little longer than stock wires. Most importantly, you can individually bend the boot to any angle you want. Should clear any header problem.
Old 07-04-2010, 09:27 AM
Joshiedoom's Avatar
There ya go.
Old 07-04-2010, 11:29 AM
billsnogo's Avatar
I am watching this with great interest! Been thinking about these for my 71 Nova, and no one has reported fitment issues. Hope you can find a good cure for these, as the price on them is pretty decent.
Old 07-04-2010, 01:15 PM
pdsq98gt's Avatar
You might want to take a look at the new body style truck wires. They have a 90* at the plug connector.
Old 07-07-2010, 11:34 AM
myz06's Avatar
Thanks for the info on the 09 up plug wires. Might just pick up a set and sell what I don't need. Anyone else in this situation interested in a wire or two? Ill probably use 2 and sell the others. Figured about $8 shipped for one or $14 shipped for two.
Old 07-07-2010, 01:15 PM
350SS's Avatar
Any way you could post up some pics? I'd like to go with the dynatech's eventually but would like to know what I'm getting into
Old 07-07-2010, 03:37 PM
billsnogo's Avatar
x2
Old 07-07-2010, 05:41 PM
myz06's Avatar
Try to get some pics in the next few days. Also picking up a set of 09 wires so I will know if that fixes it.
Old 07-07-2010, 06:28 PM
350SS's Avatar
Old 07-07-2010, 06:34 PM
billsnogo's Avatar
x2. If the '09 wires work, I will order the headers ASAP. Will work out fine since I have no wires to start with
Old 07-13-2010, 05:42 PM
myz06's Avatar
Do you have a part number for these wires? And when you say a little longer, is that a little longer then the fbody wires or the truck wires? Fbody's are shorter, so if they were longer then truck that would be great.
No 09 wires will work. I've looked at 10 Camaro and 09 Silverado and both are straight boots. Unless someone knows something I don't. Thanks.
Old 07-13-2010, 06:43 PM
350SS's Avatar
I had an '03 Chevy Express van 6.0L engine in my truck that had 90 deg boot ends... similar to this pic from rockauto.
Don't know if these would work or not...
Old 07-13-2010, 06:52 PM
myz06's Avatar
Nope, too long. That's what the 8.1l wires looked like. I need a short 90 on the plug end. Guess I might buy some 90 boots and just cut a wire and try that. I've never had good luck when I cut and make the wires though.
Old 07-13-2010, 08:17 PM
1994t/a's Avatar
same here....how long did it take you to get yours?where did you order them from?
im thinking of ordering a set of pacesetter long tubes for a 99-04 truck and seeing how they work on my nova.from looking at pictures seems like they will work in my car without much if any modification.
Old 08-05-2010, 04:07 PM
SlvrSierra4.8's Avatar
Any updates on this w/ pics?
Quick Reply: HELP! Dynatech headers burning plug wire
