How much weight do you loose wih LT headers and ory?
Restricted User
Just wondering if anybody knows how much weight you loose? I know how heavy stock cast iron manifolds are. And the cats together weigh about 15 lbs. So how much weight you guys think you loose switching to longtubes?
"drag racing tech" forum section, sticky at the top... might have to read a lil... but its a lot. when u do the pacesetters use new metal gaskets do not use the cardboard they give you, after the first puddle you go through they will blow out, and then they fuse to the header. its fun trust me-
