What Fluid for 6-speed trans?
Old 07-04-2010, 08:15 AM
randytj's Avatar
Default What Fluid for 6-speed trans?
I have a 98 with the six speed manual trans.
I want to change the fluid and was going to go with synthetic.........just wondered what others were using??? Redline, Royal Purple,etc..??
In my manual its says to use Dextron ATF, I know the new Dextron VI is synthetic.....should I just go with it?
Old 07-05-2010, 12:21 AM
Glenn B's Avatar
There is alot of debate over this.
If you stick with a factory type fluid, the stuff the dealerships sell is supposed to be pretty good.
That said, I have had good luck also with both Red Line and Royal Purple in the trans.
Also, keeping clean, well bled clutch fluid can do wonders for shifting issues as well.
If you end up not being happy with whatever you fill the trans with, you can always dump it and try something else.
Hope this helps.
--Glenn
Old 07-05-2010, 12:55 AM
Egg1456's Avatar
+1 for Royal purple syncromesh
Old 07-05-2010, 01:37 AM
sandsk8erz400's Avatar
https://ls1tech.com/forums/manual-tr...il-my-t56.html
https://ls1tech.com/forums/manual-tr...l-support.html
https://ls1tech.com/forums/manual-tr...ssion-oil.html
https://ls1tech.com/forums/manual-tr...romax-t56.html
https://ls1tech.com/forums/manual-tr...fluid-t56.html
Here's a few threads I've found when asking the same question. Quite a few of the guys talk about how RP can eat up the stock blocker rings. I've never used it so I don't have any experience with it, so take that for what it is. I've been running generic Dex III and never had problems. I do want to try Pennzoils Synchromesh, supposedly it's the same stuff as the GM Synchromesh.
Old 07-05-2010, 07:28 AM
Internet Mechanic
BlackScreaminMachine's Avatar
^ Agreed, do a search. I'm using Pennzoil Synchromesh, loving it!
Old 07-05-2010, 04:04 PM
lavoy's Avatar
the place that i got my t56 from suggested mobil 1 synthetic atf so thats whats in mine.
Old 07-05-2010, 04:22 PM
Wesmanw02's Avatar
I run Mobil 1 synthetic ATF in my trans, and its been very good.
DO NOT run Dexron VI, GM had a bulletin regarding its use in manual transmissions requiring ATF, its not a suitable fluid for various reasons.
Old 07-05-2010, 06:53 PM
randytj's Avatar
Thanks everyone..........I bought four quarts of Pennzoil Synchromesh today at Advance Auto, will get fluid changed in few days.
Old 07-05-2010, 07:21 PM
killagt's Avatar
Let us know how it go btw man you really a patient person, i cant go sleep without that pennzoil synchromesh already inside my tranny lol, cant wait couple day
Old 07-05-2010, 11:48 PM
the_merv's Avatar
I use Dex III in mine..I built it with the Tick Stage II kit..it works very well.
Old 07-06-2010, 07:05 AM
randytj's Avatar
Yeah,I know.......to many irons in the fire right now....hopefully I'll get some time in a couple of days!
Old 07-06-2010, 08:50 AM
killagt's Avatar
I hope everthing work out ok
Old 07-06-2010, 06:20 PM
killagt's Avatar
just change my t56 fluid to dex 3 ( oreilly brand ). WOW big diffrent in shift, and down shift.
Old 07-06-2010, 08:29 PM
crainholio's Avatar
It was a surprise to me how much smoother the shifts were after I went back to cheap regular Dex/Merc fluid. CAM-2 fluid here after a year of Amsoil ATD and notchy upshifts until it warmed up, now it shifts smoothly from the start.
Old 07-06-2010, 09:58 PM
killagt's Avatar
SEE !!! now I know y it say DEX III on the tranny sticker. I felt the same way. What brand did you use ? I use oreilly brand ( I heard it made by mobil ( not mobil 1 ). Napa gear oil made by valvoline.
Old 07-06-2010, 10:35 PM
crainholio's Avatar
When I installed the trans from a fresh rebuild, I used Castrol Dex/Merc. After a few hundred miles it was shifting smoothly...so I changed the fluid to Amsoil ATD. It's great fluid, but my trans hated the stuff until it was up to temp. Very notchy shifting.
I drained the Amsoil and went with CAM-2 Dex/Merc at $4/quart from the local parts store. Just whatever plain DexIII spec fluid I could find at the time.
If I'd found the Castrol Dex/Merc I would have gotten that...$14 for a gallon jug at Advance Auto.
Old 07-06-2010, 11:14 PM
killagt's Avatar
Advance auto dex/mer is made by castrol
Old 07-07-2010, 02:31 AM
LilJayV10's Avatar
My local trans builder said Mobil 1 ATF so that's what I bought. Hopefully the car will be running soon so I can test it out.
The following users liked this post:
MichaelRedding (07-14-2021)
Old 06-24-2015, 10:56 PM
sebvegas's Avatar
I just put autozone brand dexron 3.
Quick Reply: What Fluid for 6-speed trans?
