How can I tell if i have a steel or aluminum driveshaft by looking at it?
Old 07-04-2010, 09:55 PM
photoman9988's Avatar
Default How can I tell if i have a steel or aluminum driveshaft by looking at it?
I have a 99 ta and i need to know if it has a steel or aluminum driveshaft. The original rear broke, and was swapped out with one that had 3.23's, and i don't know if the driveshaft was also swapped out. How can i tell by looking?
Old 07-04-2010, 10:07 PM
rooster99ss's Avatar
the aluminum driveshaft will look silver, where the steel driveshafts tend to look a little rusty. The aluminum ones always have kind of a clean look to them. Steel ones won't
Old 07-04-2010, 10:11 PM
weaklt1's Avatar
x2....
Old 07-04-2010, 10:30 PM
Morbid's Avatar
A magnet.
Old 07-04-2010, 10:41 PM
Snake_Skinner's Avatar
who cares buy an aluminum one.
Old 07-05-2010, 07:15 AM
built408's Avatar
If you can't figure that one out on your own, I don't think you should be driving.
Old 07-05-2010, 08:26 AM
jay7199's Avatar
Originally Posted by Morbid
A magnet.
x2....
Old 07-05-2010, 08:43 AM
danieloneil01's Avatar
Great advice.
Old 07-05-2010, 12:04 PM
BigBronco's Avatar
A magnet.
Originally Posted by danieloneil01
Great advice.
This is not rocket science here.
Old 07-05-2010, 12:46 PM
^^^^x1 Registered User
FireTA98's Avatar
So did you find out or Is it hard to tell. Lol
Old 07-05-2010, 01:01 PM
brian_rs/ss's Avatar
go to track. rev to 6k. dump clutch.
Old 07-05-2010, 01:23 PM
redz_02's Avatar
If it's stock I believe all M6's and A4's with 3.23 gears had them. The 2.73 gears were steel. If you can get under the car try a magnet.
Old 07-05-2010, 01:29 PM
bballr4567's Avatar
No. M6s ALWAYS had 3.42s in them except for one year, 93. The 6 speeds had the 3.42s because CAGS would bog down the car too much with 3.23 gears from what I was told.
Old 07-05-2010, 01:55 PM
^you misunderstood what he was saying. all m6's have them...AND....a4's with 3.23 gears. he did not say that m6's have 3.23's.
Old 07-05-2010, 02:02 PM
redz_02's Avatar
Thank you for clarifying it for him.
Old 07-05-2010, 05:59 PM
bballr4567's Avatar
Gotcha. Just used to it these days with so much misinformation being spread around.
Old 07-05-2010, 07:13 PM
((((((Administrator))))))
CRAGER's Avatar
Not ALL M6's had aluminum. If you did not have the "Z" rated tire option you have a steel one and a speed limiter at like 105mph.
~ Craig
Old 07-05-2010, 10:16 PM
Spritle's Avatar
A magnet.
This.
Old 07-05-2010, 10:31 PM
70hemicuda's Avatar
Old 07-05-2010, 10:55 PM
CRAGER's Avatar
Lightbulb
Found this thread, here is a pic:
Originally Posted by Raptor_WS6
well, i have broken both... stock aluminum one and replaced it with a steel one, they both snapped
aluminum popped at the track at launch... right off the line. steel one popped on the dyno after a cam install.
~ Craig
Quick Reply: How can I tell if i have a steel or aluminum driveshaft by looking at it?
