WTB a bunch of stock LS1 parts
I need a bunch of random pieces to get my LS1 back up to par. parts need to be from Camaro / Firebird, and is possible would like all hardware included.
LS1 water pump with tensioner pulley attached AND the 6 water pump bolts
LS1 Power steering pump / pulley, and if at all possible I need the high pressure hose that comes off of the pump, or at least the fitting that screws into the pump.
LS1 balancer
LS1 Alternator plus 2 mounting bracket pieces, and the little pulley that's connected to the bigger piece.
I also need a set of compression rings off of 1 standard sized LS1 piston Both compression and the oil rings. If you happen to have stock pistons lying around that still have the rings on them, I want 'em.
Looking for a torquer V2 Cam with 112lsa.
Need all intake manifold bolts.
Fbody motor mounts. The portion that bolts to the Block mainly,but will take the other parts too if you've got 'em.
LS1 balancer
