SES for AIR even after it was tuned out
Last summer i had my car mail ordered tuned by frost and had the AIR codes turned off and they have been off ever since. After starting my car up for the first time since i put it away last fall it and driving it around for 10 minutes or so the SES light came on. I get the code scanned and i come up with: P0412. any ideas?
P0412 Secondary Air injection system Valve A malfunction
also getting
P0506 - Idle Air Control System RPM Lower Than Expected
but somehow the vac line in the back of the manifold for the hvac vents fell off while installing, didnt notice until i turned on my a/c so i figure thats the culprit
also getting
LSX Mechanic
IIRC, there's about 2-3 different codes in different locations in the DTC menu that have to be turned off for the A.I.R. systems. If the tuner didn't know all these codes, then they all haven't been turned off.
He also needs to turn off/uncheck the "SES enable" box, and set the code to "no error reported" in the DTC menu.
you just sent me the file i my brother who has hp tuner load it up for me. After driving around for 10 miles the SES light came back on and i went to autozone and used a code reader and had the same codes come up, i cleared out the codes and so far i have put another 70 miles on it and it seems to be fine.
Found you...
00 A4 cam, no stall
The calibration was emailed to you (or your brother)...
I didn't miss that code; it's set to no error. Maybe whoever loaded your tune can answer to the issue. Here is a screen shot of the DTC list in compare to an OEM 00 file to highlight the changes:
