Where to find a part??
I am needing the switch that is used for switching from A/C,defrost, vent, floor, etc... I was told this is all one piece that goes along with the temperature **** and fan speed switch. Anybody got a part number for this so I can order one, or somebody know a good place to get one. I don't really feel like tearing it all apart before I have a replacement. Also, would any 93-2002 switch fit. I know where a wrecked V6 firebird is that I could probably get parts off of.
Used one by Friday. Gotta go find one at a junkyard (cheap), b/c its possible there is something else causing the problem. Got a 2hr drive on Saturday, so I am gonna need a/c. Hoping I can use a non rear defrost unit on mine, even though it has rear defrost. I would assume any 1993 firebird, T/A will work, maybe even camaro, but i'm not sure.
Not used, but $127.79 on RockAuto.com. Sure they could get it to you before Friday.
Oh, it says it's not a stock item...would ship within 5 days.
ACDELCO Part # 1572293 More Information About this Part {#16216462}
Looked on Hawks Third Gen and couldn't find anything.
Unfortunately, my a/c problem is in the clutch and not the climate head unit.
Guy is gonna check it out 2mrw, hopefully something can be done to fix it w/o costing me a arm and a leg.
I need some O2 sensors. What is recommended-AC delco,denso,delphi??? I would prefer not to use the cheap ones at my local parts house.
Also a AC clutch kit.
